Missing pulse (x2) detector
jdbrandt
Oct 2002
Pennsylvania
1,203
I know somebody makes this, I just don't remember who.
Input 1: A pulse train of frequency 'x', and duty cycle of 'y'
Input 2: A pulse train, also of frequency 'x', but a duty cycle of 'z'.
Output A: ON is when
Input 1 is ON for a long time, or OFF for a long time
-or-
Input 2 is ON for a long time, or OFF for a long time
-or-
One of the inputs changed state twice, while the other input changed state only once (dual Missing Pulse detection).
In the old days, I would have gone to Eagle, Dynapar, Veeder Root, et al.
But, in the new days, I would think this would be a DIN rail mountable thing.
Anti-coincidence summer ???/
Is this intended to work with a quadrature encoder signal to detect zero speed and/or encoder signal errors?
Actually, each input is a proximity sensor.
The total time period is ~300 Ms.
One duty cycle is 50/50 - - - 150 Ms on, 150 Ms off.
The other duty cycle is ~ 3% on. In other words, a pulse, about 9-11 Ms in ON length; the balance OFF.
I would and could do this with a PLC - just not the PLC I have. The I/O update is not fast enough, and can't be easily made to be fast enough.
Hi to the forum. I have an AC inverter with current speed as a pulse or analog output - standard on most drives. I have a sensor on a turntable. I...
2,545
I would like a sanity check on an application i am working on. I have a proximity switch counting pulses with a Mark/space ratio of 1:1 on a...
1,879
I was having a problem with a MicroLogix 1000 processor (DC model 1763-L16BBB) missing pulse counts from a hall effect (NPN open collector) flow...
2,591
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics show not only blower...
99
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
81
