Mits FX2n programing cable
stooperbike
Oct 2004
New Hampshire
78
Hello All,
Been a while since I have worked with a Mitsubishi FX2n PLC. I do not have a programing cable so I went to order a new one, the gentleman at tech support suggested the USB FX-USB-AW. BUT its not cheap. I already have a USB serial adaptor so I was going to order the old SC-09 cable. BUT then I searched amazon.com and found http://www.amazon.com/USB-SC09-FX-p...adapter/dp/B0079G3PLY/ref=pd_sim_sbs_indust_2
way cheaper. So long story short, anyone ever used one of these from amazon? Yes I realize amazon is a warehouse and I can but this and parts for my motorcycle there but I was unsure if this was an actual Mitsubishi part.
No its not a Mitsubishi part... just like myself there are after market manufactures, these are the ones we offer http://www.ind-concepts.com/AD_Mitsubishi_Omron_PLC_Cables.htm
I would recommend buying from someone that can issue support, I think you would be SOL asking them for support
They also have this cable listed as a S7 -200 Siemens cable... Mitsubishi PLC's are 422 and Siemens are 485... so something is not correct
Hello, I'm trying to create a faceplate that features a bar where a real PLC tag is passed through the faceplate interface. I want to check the...
336
We're converting a SLC 5/05 to 1769 CompactLogix. The existing PLC is spread among two cabinets, with five racks total (last two racks being read...
1,645
Hi, Is there an easy way to limit the input tag by using min and max tags from the PLC? Thanks
1,277
Do people typically use both end limit sensors and configure soft limits for linear servo axes? I thought this was standard practice until one of...
5,808
Kindly at which temperatures are the servomotors ok to run? We are trying a machine for long periods, and some of the servo drives displayed a...
2,434
