Mitsi F1-30MR programming question
Johnny T
Jul 2003
Fife, Scotland
642
I'm upgrading an old Mitsubishi F1-30MR PLC to an FX-1N 60MR.
The old PLC is broken and all I have is a hand-written bit of software to go off.
Some of the software is pretty straight forward. Some of the numbers refer to the outputs and inputs but there are some number such as 50, 51, 52 etc that I wondered about. Are these just markers or are they internal registers or something else I need to know about?
I'm not very familiar with Mitsi, I've more experience with Siemens so wondered if you could help me out... here is a pic of the listing that I'm going off...
Any light you can shed on this will be greatly appreciated.
JT :)
Hi JOHNNY T !
Are you sure that the code has 50 , 51 , 52 & NOT S1 , S2 , S3 ?
Mitsubishi FX series has STATE RELAYS which are denoted by S--.
Purpose of S relays is - Internal Programmable Controller ( PC )
status flg.
Available contacts - NO , NC
Device numbering - Decimal.
I could not locate the site for FX manuals immediately but you can get more details on www.mrplc.com
Hope this has served your purpose a bit!
regards
asp
reachasp
I've looked at them and they definitely look like 5's, it seems to be 50 through to 57.
The PLC is a F1-30MR which is an old one.
Could they be internal flags? Or could they be state registers still?
JT :)
We've got 2 cooling fans on our system. They switch on based on water temperature. One switches on at 25c. The other switches on at 30c. The code...
3,093
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,229
Hi all, I'm not all that clued up on GX Developer with A series CPU. I have an Ethernet module A1SJ71E71N3-T and for the life of me I cant...
1,422
Hi, I am trying to communicate with a Mitsubishi A2A CPU using a MEDOC SC-03S2 interface, my Mitsi. programming software is MEDOC V2.30 For some...
1,836
Hi, I have just wired up (might be incorrect) a Q Series PLC with an Input Card GX40-S1 and an Output Card GY40P. my issue is now in software I...
1,586
