mitsie fx plc unit
michael59
Dec 2002
19
I've done this program for college and I'am abit unsure of the unit I need to run it could you please tell me if I 'am on the right lines.
THe program is in fx and uses 51 inputs and 51 outputs so i thought the main processing unit could be a FX 64 MR-ES/UL.
There is also a bcd part of the program used to give a visual display using two seven segment display units for this stage the use of a powered extension unit fx 32ER-ES/UL or the unpowered unit FX 16EX-ES/ul.
And the final part of the program uses the analogue to digital conversion statement and so for this the use of a special functions blocks FX-4AD analogue input and the FX-2DA analogue output block
My question although long winded is will this work for what I need.
If the 102 I/O (51+51) you need are for your main program then the FX 64 MR-ES/UL will not do.
The '64' part means total I/O and I think it is split 40 inputs - 24 outputs.
So you will need a FX128 (64 Inputs / 64 outputs)
And then again I am not sure that The FX do 128 I/O and they are also going out of production.
The FX2N certainly do 128 as I have used them.
The rest of the parts would be ok though
174
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
184
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
38
247
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
