mitsubishi alpha xl 2 tachometer
steifanc
Jun 2010
dublin
hi guys ,
im trying to get a rpm reading off a shaft of a low rpm rotor, the roter speed is well less than 200 rpm ,
how would i go about this with the alpha plc ? . im using a standerd proxmity for the pulse , do i need a magnetic pick up . i can use a counter and it counts most of the pulses of the proxy , but when it speeds up it looses some of the pulses , also tried the speed detect , but the same thing happens , im not really sure what i should be doing , is it a case of the proxmity just isnt up to the job ? i selected my input as a analoge dc input and used a smith trigger to fire into the speed detect over 1v , at higher speeds i dont reach 1v tho ,
what would the normally of mesureing rpm ?
thanks for any tips
stephen !
it has an analoge input , i have selected the input as a analoge dc input , so are you saying try adding a one shot pluse to the signal ?
thanks for your post
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
69
I am trying to connect USB to RS232 cable to the RS232CAB that is used with the Alpha series PLC. I am getting a failed to open com port error...
1,358
I have downloaded a project from a Mitsubishi Alpha PLC that we are having issues with and the representation is Boolean. Is it possible to...
1,679
Simple question, is there any way of saving Function Block Output values on power down in Alpha2? Or more general question, is there any way of...
1,582
Hello ALL, Have some experience with PLC programming, however I'm quiet new to Mitsubishis ALVLS-EU Alpha controller software V2.70. What I need...
1,868
