Mitsubishi E Designer
Michael Bell
Mar 2004
Washington England
96
Maybe someone has come across this before and can help.
I am programming a Mitsubishi (Beijers) E1032 HMI with E Designer 7.20.
If I add a Local Function Key and use the KEY FIELD function to create a label above it, it works ok. If I delete the Function key and the text in the KeyField, the field shows up filled in solid black.
The 'SHOW EMPTY KEY FIELDS' box is NOT ticked. The solid fill does not show up until I download to the HMI, or I use the simulation facility in E Designer.
Thanks in advance to anyone who knows what to do.
E Designer
I have just discovered this.If you look on the Languages toolbar, there is a button that says' shows index instead of texts' its symbols a T which changes to an @. This shows up some characters preceded by an @ deleting them got rid of the black boxes.
I had some comm's problems (USB to Serial and the whole project didn't transfer properly. I changed to proper serial and it was ok, I think some of these references with the @ symbol must have been left behind from a failed download.
I have a customer that has a GT1575-VNBA and I think they are using GT Designer. They have the software and program for both the HMI and the PLC...
2,335
Hopefully someone has had more experience in this than I have. I was tasked with making a recipe function for a project. I've done so based on...
2,705
Hi id like to connect my wago controller with mitsubishi hmi and im using codesys 2.3 and gx designer 3. Id like to know how i know what register...
4,684
I am trying to back up a Mitsubishi GOT A970 with GT Designer 2 Classic. The back up seems to go fine but when I open up some of the screens some...
1,469
Anyone know how to use a different pop up keypad for numerical entry. I would like to have a custom keypad other than the default one. I think I...
2,487
