Mitsubishi E200
kiegmann
Apr 2006
Winona, MN
26
Does anyone have info on how to program this OI from the terminal, or a link to it? I can access some of the configuration, but not all. So far I am unable to get it with a laptop (perhaps a processor speed issue?) The OI is at least 8 years old.
Michael
You need the E-Designer (or E-Designer Lite) software and a CAB5 cable. You should have no problem getting online with it, but beware of USB to serial converters. Not many work well with the Beijers screens. I've found the Keyspan USA-19 will work with E-Designer.
Thanks Crossbow, I do have E-Designer 7.1 (and higher on another Laptop) and CAB5. The laptop I use is a 266 MHz with serial ports. My guess is that the build version won't work with 7.1 I know that if I can get the program out I can get it into a new one and save some money (not that I'll ever see it :{-). I am quite limited on time to work on this. Ny normal job duties do not allow it.
If the firmware version in the screens is older, you might be able to use the older E-Designer 6.13 to get the program. Check the firmware in the screen and the available options in the 7.1.
You should have no problems uploading and downloading with what you have.
There is a problem on some HMi's, came across this recently.
An original was done with 5.xx
A new panel (E700)was fitted after operator destroyed keypad with same firmware version, but using V6.xx this failed to load all message libs, so decided to try 7.xx, this loaded all message & screens etc. but then the driver did not work, found out that when I loaded the original app, the driver needs to be re-selected in peripheral setup.
Had no problems after that.
Dear, please tell me 1) How to see version of E200 Mitsubishi HMI? 2) Is there any need of going into any transfer menu in the HMI or it can be...
3,434
I was flashing the firmware on my E200 and the progress bar was almost at the end when it froze. The HMI display was stuck on "sysload" at the...
18
7,520
I need to display the temperature of a system on an E200 Screen from a 4-20mA PT. for 0-100 degrees. What should be the offset & gain settings...
4,666
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
37
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
