Mitsubishi F1-40MR
nightowl120
Mar 2008
Massachusetts
Hello, I have an older Mitsubishi F1-40MR PLC that I would like to upgrade to a AB 5/04. I have verified the program using the keypad to make sure my printout is correct. Does anyone know where I can find the programming manuals online for this unit. In the program there are PLS, S and R coils. I believe the S is set and R is reset and I'm guessing the PLS is the same as a one shot. I also want to find out if the timers are all time delay on. The program also has a counter. I would like to fully understand all of the instructions before converting.
Thanks.
Thanks.
If it is as simple of a program as you describe why would you want the processing power of a 5/04?
Just a waste of hardware. Unless you have it around in which case just use it.
2 things...
All F manuals are in the Downloads section at www.meau.com. Select Industrial Automation, then PLC, then PLC-F. You'll find F, F1, F2 manuals all there.
SLC 504 is ridiculous overkill. Why not try a Mitsu FX1N or FX3U? Most comparable AB would be MicroLogix.
Thanks for the quick reply. I found the manuals on Mitsubishi's site.
The reason for the 5/04 is because I have a few around and this will allow me to connect this machine to Wonderware (on the DH+ SST card). I have 5 other machines connected to Wonderware with 5/04's. The Wonderware computer is also connected to Wonderware's Active Factory program. The other bonus is I can install a Panelview 600 to replace an old Veeder-Root counter (which I have done to another machine).
Thanks.
Dear Sirs, I have two Mitsubishi FXon-40MR-ES PLC's to play with. I have the GX developer-FX ( Melsoft ) software Version 8.25B to program and...
2,443
Friends! I'm currently doing a HNC in electrical Eng at college and part of the course involves a project. Part of the project, I have been...
2,216
i am using mitsubishi plc FX1N-40MR & analog module FX2n-8AD with it, i want coding that plc accept input analog voltage from -10v - +10v which...
4,354
Hello, I have a Mitsubishi F1-40MR and I have a question about Special Functions. I have the following ladder logic in my program: |...
2,909
I guys i have a Mitsubishi F1-40mr that i am having a problem with, I was thinking of getting it repaired because i no longer have access to the...
3,954
