Mitsubishi FX2N Communication Problem
Jun 2015
Lahore
I am trying to communicate with Mitsubishi FX2N through RS232C. But unsuccessful all times i tried. I tried to communicate after change the pin configuration but void. Anyone please tell me what is the exact pin configuration of RS232C (PC) to Minidin 8 pin(PLC FX2N).
What do you mean change pin configuration? PLC communication cables are designed to communicate from PLC to computer, no need to change any pin unless you are making your own cable.
Below is the set up you may use
PC side I/F Serial/USB
When using RS232 use COM 1
PLC side PLC/Module
Other station No specification
Note: make sure you set your PLC type to FX2N series
thank you for your reply.
I am making my own cable, that's why i asked for pin-out.
Previous reply is also great and helpful for communication configuration.
Regards,
It doesn't work. What if i use e terminals that is connected with plc.
What option i have to chose to communicate and what transmission speed.
Mitsubishi
Hi Usman,
I faced the same problem before, I tried Danatomega configuration, it works fine for me.
Try to check other factors.
Hagos
Hello, I would like to use RS function for communication with another PLC.... I have FX2N-485BD modul....connected two wires Sending from PLC...
2,643
I want to communicate delta HMI dop-b to mitsubishi plc fx2n.hmi program is ok offline.it is transferred to HMI but no communiation.com port...
6,409
Hi there! Have no experience with Mitsubishi PLC, need to connect FX2n-16 MR PLC with E200 operator pannel, what cable can I use ? Also please...
4,620
I am working on a job trying to add a FX2N-232IF to a fx3u PLC. I have never worked on a mitsubishi PLC before, although I have years of PLC...
18
8,054
I have a query regarding communication between Mitsubishi FX2N PLC & HMI EZS6M-R from automation direct. Mitsubishi plc has two ports one is RS422...
17
25,456
