Mitsubishi Fxos Problem
lightninguk
May 2002
Warkwickshire
24
Hello all
Anybody know what it means when the plc power light pulses on and off. The run switch is in the run, but the run light is not lit.
NO error light at all.
We have 240 volts going in on the mains supply. No volts on the on board 24v dc service supply.
Any ideas
Regards
Lightninguk
I had an Fxos do nearly the same thing a while back.
The run light on mine did come on - but then everything went off and the plc shut down - then re booted and started again.
If its not so old they come with a lifetime guarantee now (reading the small print a lifetime means 10 years)
Mine went in the bin and a new one fitted.
Hi All I have a mitsubishi FXos-30MR-ES (100-240AC supply version) that went dead after plugging in the SC-09 programming cable while trying to...
3,859
Hello I am having Mitsubishi PLC FXos-30MR By mistake we have entered wrong key word ( pass Word ) and not able to recall. The PLC is not able...
9,257
I need help? I don't know much abought this PLC. I need to know how to make a timer work. I'am tring to start a timer when I start a pump. Thanks
1,887
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
56
