Mitsubishi GS2110 Download Error
Cwz90
Jul 2011
Penang
22
Hi All,
I do have a project using FX5U-32MR/ES PLC & GS2110-WTBD-N HMI.
I am using GT Designer version 1.109P. However, there is an error during downloading and it stated "The GOT type is different or unsupported." as shown in attached.
It will much appreciate if anyone able to advice for this.
Thank you.
Best Regards,
Cwz
The only things I can suggest either the GOT is a different version or your GT Designer is older than possible GOT version. perhaps display the got version compared to your project.
There is an app that I had to install on my computer to enable me to program GS series GOTs. I think I got it off Mitsubishi's website. I have it listed as GS Installer, don't know if that was the original name.
There are two versions of GS HMIs. With old without "-N" in name, and new with "-N".
You should check in "System" Docking window->GOT setting->Type Setting if you have selected correct one.
Hello Friends I have a machine with a barcode reader connected through serial port to a GS2110 HMI and a FX3G CPU. Where can I found the tag...
1,664
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
71
hi all, I'm wondering if anyone has ever converted an Allen Bradley AOI to a Mitsubishi Function block. I's hard to find libraries from...
178
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
195
