Mitsubishi Parameter Mismatch
smahon
Jul 2005
Dublin
Apart from bad management of program backups has anyone ever come across a problem with parameter mismatching when attempting to go on line to a Mits A-series or Q-series?
Parameter mismatches used to be a common problem for inexperienced Medoc users but I am not sure whether the issue still exists with GX Developer. The problem occured if someone uploaded a programme from a PLC but forgot to save the parameters before they quit the project. Medoc required you to save the parameters and the programme seperately. As there was alomost no reason for anybody to go into the parameters after the initial setup of the project it was very easy to forget to save this file.
I use Mitsubishi A and Q series most of the time. I have not found any problems with parameters mismatched.
Parameter mismatch occurs when you have set wrong or no parameters in 'parameter setup'
Usually it is the number and type of I/O you have plugged in.
Until you get the program on your laptop to match the program/parameters to the real physical ones - you will get this error.
You can either set them by looking at the rack and entering them in parameters - or by uploading just the paremeters.
This is i my experience a most common problem with them Q series.
I recall having this happened to me many times when I was programming some rack in my shop through a modem (direct to a serial card) or through the transparent port of an HMI (from a PCAnywhere setup) or through an Ethernet card.
Sometimes I had to re-download the hole darn thing.
Seems that 3 way programming capability was tooooo much for them :(
Sometimes I was loosing the serial card setup parameters and it was giving me these results.
I've got a bunch of alarms in GT designer3 and they are "mapped" to M parameters, eg M277. What does M signify? Thanks
2,273
Hey Every one I am trying to set to frequency of vfd to 100z but cant the parameter #125 is the parameter to set the frequency of vfd more than 70...
2,203
Hi, I have just started with Mitsi PLC. Have a bare rack with only power module and a Q01. Have a new project, one test rung. After transfer I...
3,059
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
53
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
59
