Mitsubishi PLC comms
QMS_MAN
Jun 2015
uk
Hi All,
I have two Mitsubishi Q series PLC's ( Q03UDECPU ).
Both are connected via a basic ethernet switch.
I need to read and write about 100 words of data between each PLC.
This is not a high speed application.
This is a new project using GX Works 2.
What is the best way to achieve this task.
Any help or examples appreciated.
Thanks in advance.
Hello,
You will need to go into the PLC parameters in GX Works 2, under the Ethernet port tab go to open settings. In there you can configure the communication between the two PLC's.
Hope this helps.
Dave
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
115
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
162
