Mitsubishi PLC comunication
roxtech
Mar 2008
Township Lahore
198
Hi dear,
kindly help me to find out IC number for given RS232 to RS422 converter pcb. One IC is Max232. check attached file and help me to make home converter. I trace this converter but local manufacture rub IC number.
Did you produce the attached document containing the circuit board drawing?
Hi dear,
No I trace this ciruit from converter which is working ok on A series PLC. Now I was trying to build this converter. I try to use IC AM26LS31 and AM26LS32. but i got no comm. error may be some PCB ERROR.
If you have an HMI, either E-series or GOT you will only need a null modem cable or a variation of it for the E series HMI. With a Misubishi you only but the converter once in the cable. Other brands of PLC's build it into each unit and you pay when you but the unit. Check the price and you pay more than the $100usd for the converter each time but it is covered in the cost.
Hi there I have tried every resource I could to get my lap top connected to A series mitsubishi via MD11 programming port. There is a Proface...
2,161
hello im cheking RS232C comunication between the plc mitsubishi, and the interfaz tarjet AJ71C24, between a PC-980iVm2E, brand NEC. the pc...
2,465
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
53
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
67
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
163
