mitsubishi plc fx2c output problem
heweijie2007
May 2008
HCM CITY
i just work with fx2c-96mr, when turn plc mode to stop, and use software to force output,output light will light on, but when plc programming is run, use software to monitor, specical output point is on, but why plc not really output(output light is still off),just happen with some output point(not driven m8034)
try following:
- is cpu running and what is the scan time?
- is the actual code scanned?
- is something else clearing output (double coil for example)
- are you looking at the right address?
- can you post your test code so we can look at it?
Try to force on for example Y0, you can monitor if it is energized or not. If energized, then check with multitester if there's an external output, either test the continuity of com0 and Y0 (just make sure there's no voltage if you check for continuity), or check the voltage output of Y0 if there's a power supplied. If there's no external output, then maybe the hardware of your output module particularly the relay for Y0 (coz it's a relay output) is defective.
Other than that, try panic mode's advice.
james
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
141
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
118
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
165
