Mitsubishi PLC help
Where are you finding these instrucntion? Are you using GX Developer? What CPU are you using?
My version of GX Developer does not even recognize what you have there.
Hello,
Those instructions are positioning control instructions.
The DABS instruction reads the absolute position (ABS) data when the Mitsubishi servo amplifier (equipped with the absolute position detection function) MR-H, MR-J2(S), or MR-J3 is connected. The data is converted into a pulse when being read.
The DDRVI instruction executes one-speed positioning by incremental drive. The movement distance from the present position can be specified with a positive or negative sign.
These are the basic explinations out of the Mitsubishi FX Programming manual. The FX Positioning manual explains these instructions in detail.
Hope this helps,
Dave
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
60
Hello I am new in Mitsubishi PLC's so I have a request to convert a program which is running in a Q06H CPU to the same machine but running a...
2,001
Hello my friends.. I have a machine with Mitsubishi FX48MT plc. I did a simple change in program, a free input disable a existent output. I...
1,500
I'm using INC function with D0 register. But the result after i press the switch is not D0+1 it is a random number(usually hundred or thousand...
1,720
I have the question in a text book ive tried a few times to answer it the problem i have is every script i write for it the plc reads it as if b...
1,336
