Mitsubishi PLC to PLC ascii data transfer
tbca
Apr 2010
woodstock
Hello everyone,
I need to transfer ascii barcode data from one Mits PLC to another.
Whats the best way to do this? Ethernet...Melsecnet???
Thanks,
Jeremy
Ascii is usually adequate and most commonly used on most PLC platforms, Particularly with barcode applications. I know Mitshibushi can handle it but not familiar with particulars with that platform.
What PLC's are to be connected, CPU-type?
Do you have any communicationscard installed already?
How many data do you have to exchange?
If both PLC are Mitsu ex.Q-system, you could use CC-Link it is a cheap and easy to setup.
Best regards
Dariusch!
we need to transfer from a Q to an A. These systems already have cclind cards. we can use cclink to tranfer data??
You can set up the data-area to read/write in the
Parameter -> Network-Parameter ->se pic
It is almost the same with GX-IEC
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
140
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
94
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
118
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
165
