Mitsubishi PLSR Command
demmons
Jan 2009
PA
87
I have a Mitsubishi FX1n processor and am using the PLSR (Pulse Ramp) function to control a stepper motor. I would like to control the accel independently of the decel. Can I move a different ramp value into the PLSR command after the motor has accelerated to full speed to allow the deceleration to be a different value?
thanks
actually, you can control the following using plsr:
1. frequency
2. number of pulses
3. ramp up time
when you wish to give a pulse more than 20000, then your command should be like this :
ex.
LD X0
PLSR K500 D0 D1 Y0
OR USING DPLSR :
LD X1
DPLSR K20000 K50000 D6 Y1
regarding of the ramp value, i think you cannot change the ramp up time from ramp down time. because they have the same reference (S3). and there is no completion flag for the PLSR halfway. completion flag (M8029) is on when pulse ramp completed its execution from ramp up to ramp down.
but first, before executing this command, be sure that your FX1n PLC is transistorized type.
hope it can help.
So the customer purchased a Mitsubishi drive, in the same project for a different pump they got an ABB drive, was literally whatever they could...
71
hi all, I'm wondering if anyone has ever converted an Allen Bradley AOI to a Mitsubishi Function block. I's hard to find libraries from...
178
195
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
80
