I think that indicates a processor memory error, could be wrong. Try cycling the power, leave it off for a couple of minutes.
Double check all your wire connections, I had a loose incoming power lead cause similar faults once before. "Brown" outs and poor grounding seem to scramble the ML, more so than other AB lines.
If that doesn't do it, you will have to contact AB.
