Ml 1500
hagos
Oct 2004
Africa
244
Dear Folks,
Iam looking for a help, I had a call this morning to look after a problem in an Allen Bradley ML1500, I want to go there prepared.
I have a RS Logix 500 (which I usually use for my ML1000), my question is: Can I access the ML1500 with the same software(i.e the Logix 500)?If not , what would be the suitable software.
Awaiting your help as usual
Cheers
Hagos
It all depends, are you using the free version RSL500 for the 10 point ML1000? If so then NO it will not work. The ML1500 has a RS232 (DF1) port but can have a 2nd port.
The ones to ask would be the ones that have the ML1500 i.e. what model is it and is there anything connected to its communication channel(s).
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
104
129
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
361
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc. attaching from settings. Have i missed anything? Both plc and...
332
