Ml1400 clock
ewok11
Apr 2016
dunedin
I'm trying to use the clock but I can't seem to get it to start.
I click on set time/date but nothing happens am I missing some thing .
Going from memory but did you purchase a real time clock [RTC] and plug it in to the front of the unit?
HTH
No RTC module needed with the 1400. Are you online with the PLC when you hit the "Set Date & Time" button? It won't work if you're offline.
What kolyur said + it automatically goes on its own, you don't start it.
Under the Set Date & Time button does the next button say Enable Clock or Disable Clock? The clock may be disabled.
Like Kolyur says, I think that you have to be ONline.
Look under Controller: Function Files
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
514
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,449
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,231
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,838
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
848
