ML1400 ethernet connection
bruzynski
Sep 2012
Toronto, Ontario
Does the ethernet port need to be connected to a switch or hub before it is connected to a wireless adapter?
I have a ML1400 connected to LAN port on a MOXA AWK-3121 setup as a client talking to another moxa setup as AP. But when every thing is first powered up the ML to moxa ethernet connection blinks a few times but never establishes a connection. If i pull the patch cord out and put it back in the connection gets established right away...is driving me nuts. Does anyone have an idea what is going on?
Technically/Officially, you should use a crossover cable between the ML and your Moxa if there is no switch/hub in between. Perhaps it's an auto-crossover issue not detecting right away properly on power up. The Moxa has MDI/MDI-X capability, but sometimes I've seen for some reason, this feature doesn't quite cooperate with PLCs.
If you have a crossover cable and some time, try it!
I tried a crossover cable but it didn't work. This why it was causing me such a headache. I have a feeling that there is an issue with the radio's updated firmware...but how do I prove that?
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
848
Hello, I am trying to use micrologix 1400 Ver.A as adapter and a Productivity P1-540 as scanner, only Ethernet/IP is supported by ML1400 Ver.A...
1,859
Hi guys, newbie question here. I have my ML1400 Communicating on an Ethernet network (Ch 1 ). I also have a pH controller that can communicate...
1,768
I am having trouble where upon power up the ML1400 fails to communicate to any other network devices. If the ethernet cable is removed and...
3,771
Hello, I have an application with 12 FTView ME computers connected to a MicroLogix 1400 using Ethernet. My application works fine but the reaction...
3,090
