ML1400 Serial Port (CH2) is not sending messages
Aparras
Apr 2013
Santiago
Hi everyone,
I'm getting a little bit experience in automation world, and now in PLC programming, specifically on Allen Bradley. I'm communicating a Micrologix 1400 with an external device via CH2 of PLC, sending periodic ASCII codes. My program yesterday seems to be fine, but today is not working, because serial port is not writting on the external receiver. When I download my program on PLC just the first scan works properly, but on second I've got no results.
Any ideas of this problem?
Attached you will find my program.
Thank you,
Alberto Parra.
Mi Querido Alberto:
It seems that you´re trying to do several things on the same channel at the same time. Try to do one thing at a time.
Suggestion: download manual 1766-RM001 go to chapter 21 (ascii instructions, do not forget to use ABL and ACB instructions when reading from CH2.
Hiii. i am trying to read the PLC-5/40c data to the ML1400 PLC throgh channel 0(25 pin to 9 pin pin configuration). When i downloaded the program...
17
5,020
First time trying this particular combo. ML1400 and PLC5 over radio. Initially I used 2 PLC5's and set them up to talk across the radio link and...
20
5,951
Do this happened to any of you ? I just succeeded connecting a ml1400 true a new XPmode VM by the means of ethernet. I used a direct cable from...
3,693
Hello I am trying to communciate ML1400 via rs232 ch2 to a device in order to send comands and retrieve info, I have read some examples, I have...
2,025
hello friends i am communicating my ML-1400 PLC(SERIES A) with some device (currently I am using a microcontroller based on ATmega 328 popularly...
4,001
