MLX 1100 Intermitent ASCII Write/Read Problem
CRB
Feb 2010
carlisle
Hi All,
I wrote some code for a small hydro scheme a couple of months ago. Part of the project was to read data from a grid analyser via RS232. I wrote the attached code and everything seemed to work fine. Last week the customer called to say that the system keeps going offline due to a comm's fault!. He also said this has happened a couple of times during the first 2 months of operation, but had now become so frequent the plant has been shutdown.
PLC: Micrologix 1100
Grid Analyser :Circutor CVMK Series
At this stage I don't know what error code the control word of any of the ASCII instructions is showing, I hope to get to site on Tuesday to investigate.
I'm a bit wet behind the ears when it comes to ASCII, could someone have a look at my code (LAD 5 - Grid Analy). Any comments on better practices with regards to ASCII would be greatly appreciated.
Cheers
Chris
hey guys, i am having a problem communicating to a mlx-1100 from a plc-5/40 with a enet sidecard. i believe i have everything set up right with my...
2,360
Hey Guys, I am struggling to read data from a "JUMO" make controller using modbus RTU with MLX1400. The communication between the devices has...
18
5,174
Is it possible to create MSG in SLC to read data from a mircologix 1000 via serial DF1? I have Micrologix 1000 and SLC5/04, the serial port on...
1,815
HELLO BOYS, I HAVE AN INTERROGANT, HOW CAN I MIGRATE A PROGRAM FROM A PLC MICROLOGIX 1500 TO A PLC 1400:beerchug:
1,639
Newbie question here, I have been trying to setup a Ethernet/IP network consisting of 3 AB Micrologix 1400 plc's, one Idec HG4G-CJT22MF-B OI, and...
3,354
