MLX1400 and PowerFlex525
Oliver Micka
Oct 2015
Hlohovec
65
Hi all..
I would like create comm between MLX1400 and POWERFLEX 525 trought Ethernet..
I know, answer is a here:
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/52205
But N-files in the drive have be a max: 3 words
N41:0 ( N41:0-N41:1-N41:2 ):
N41:0 - status word/control word
N41:1 - not used
N41:2 -Speed Reference/Feedback.
I need read "Actual Current" and "Fault Code".
Does anybody know, how can i read those data trought N-Files?
A one idea is use CIP Generic MSG instruction and continuing via this manual:
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/721115.
But i dont know, how can i write command word and read status word.
Hi folks, I am trying to fetch data from flowmeters of Krohne make using mlx1400 over RS485. The architecture as follows: Krohne device -----...
1,389
I have an OEM customer that has been building a small machine using a MicroLogix 1100 which is now discontinued. I have recommended that they use...
32
5,394
Hi all, Please, could someone give me a working example of how to use the RHC instruction? I want to measure the speed of a machine that works...
1,435
I had to replace a hosed-down PV+7 (2711PT6C21D8S) which connects directly to a MLX1400 via ethernet (no switch). The addresses are static and...
2,233
Hello all. Is there a way I can have values at certain intervals stored on the SD card for the MLX1400....maybe triggered alarms also? I have used...
1,404
