Mobile panel 177/WinCC Flex 2007
Cryogen
Oct 2005
NH
151
I am using a Mobile panel 177 DP with S7-200 PLCs. Everything worked fine, I programmed it with WinCC flex 2005 (SP1,HF4). Recently, I upgraded to WinCC flex 2007. Since then I haven't be able to transfer the application to the HMI. I did an OS update successfully but cannot do a transfer.
The serial channel on the Mobile panel is enabled and I am using the serial RS232/PPI multi master cable. I tried all combination for the DIP switches. I am able to connect and transfer to a TP177 so I am pretty sure my cable, COM port works..
Any help would be greatly appreciated!!
Thanks!
If anyone is using WinCC flexible 2007 successfully to program a HMI, can you let me know
- if you are using the serial port on the laptop
- the EStand number on the RS 232/PPI multimaster cable
If you did a OS update your com settings should be good in flexible. Make sure the settings in the panel were set correctly after you did the OS update. I have seen them change after doing an update.
Do you have the "Output" dialog (Ctrl+Shift+O) open when you transfer? and if so is there any Errors after compliation?
If you can OS Update then i'd say your connection is good. But i have also experienced Settings loss in the CE Control panel after OS update so double check them.
Also can you verify your cable by connecting to another device?
edit: I deleted something I wrote about MPI/DP. Nonsense on my part, because as you have done an OS update, we know that the panel is reachable via serial/PPI.
Redo the exact same setup as when you did the OS update. And then check the error messages in WinCC Flexible if there are any.
I'm trying to transfer a project via MPI Routing to a Mobile Panel 177 DP. Problem is that an OS update needs to be performed before the transfer...
2,008
Dear Every Body, We are seeking with a problem to upgrade the Siemens Make Mobile panel 170 by Mobile Panel 177. The system is running by...
12,236
Hello All, I am hoping someone can help me out since I know Jack about Seimens PLCs. I have been given the task to figure out if a Siemens s7-200...
4,610
Hi This is the first time i try to have OP communication over profibus but so far i havnent been able to get it working. What steps are...
5,632
I`m searching for a remote mobil panel (battery driven), for controlling some IO on a PLC. The remote mobile panel need to be approved for Atex...
2,088
