Modbus 485 connection wiring
sultanahmed
Jul 2013
home
63
I am working on Accuload 111 want to read/write data through modbus 485 through modbus poll software.
In device modbus connection shows RX+ RX- Tx+ Tx- conection. i have 2 wire seneca 485 to usb convertor i connect it with rx+ Tx+ is this configuration ok?
Please advise?
Please advise?
Link RX+ to TX+ and RX- to TX- together on the 4 wire end and connect your 2 wire USB lead to the + and - you have just linked
4 Wire_________2 Wire
RX+/TX+______+
RX-/TX-_______-
edit, just to note that wiring like this will only give you half duplex communications, not full duplex
Hallo . I have a project to connect the Battery flow meter from SIEMENS Type : MAG 8000 ( RS 485 Modbus ) connection with USB MINI PC ( Simatic...
3,912
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
246
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
151
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
211
I am trying to figure out some communication specifics for a Modbus RTU network that I will be integrating with and could use some help to make...
2,116
