Modbus Module MVI56-DH485R
salman111a
May 2007
KARACHI
20
I Have To Communicate 02nos Slc Controllers (slc 5/03)to A Control-logix Controller Using Modbus Module Mvi56-dh485 , I Have Made A Network Diagram For This Particular System Of Mine , I Am Attaching The Network Diagram , I Shall Be Very Thankful If Some One Can Verify This Network Diagram Of Mine Or If Some One Finds Any Problem With This Digram Kindly Notify Me That As Well .
Your diagram is correct. Just the cat. number for 5/03 isn't 1747-L31E but it is 1747-L531 (also E is only the series of the processor).
So, about the DH-485 connections, all is correct.
Only I don't know about the DH-485 cable, following the specifications Rockwell gives on its manual:
The suggested DH-485 communication cable is Belden #3106A or
#9842 cable. The cable is jacketed and shielded with two twisted wire
pairs and a drain wire.
One pair provides a balanced signal line, and one wire of the other
pair is used for a common reference line between all nodes on the
network. The shield reduces the effect of electrostatic noise from the
industrial environment on the network communication.
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
I am using a MVI56-MCM Modbus Mater/Slave Communication Module for a project my company is doing. I am writing all of the software(RSLogix -...
1,880
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
283
Hi hope all are ok. I have mitsubishi PLC Q03UDV CPU. I have control a drive through modbus inteligent module QJ71MT91 in GX Works2. Any experts...
639
Hi all, I have an application where there is a Control Logix PLC connecting to a B&R remote I/O station over Modbus TCP via a prosoft MNETC...
1,921
I've worked on a handful of projects that relied on a Prosoft module for Modbus comms with other systems (older PLCs, boilers, chillers, much...
2,172
