Modbus RTU/Modbus TCP. Terminal server?
marcius
Apr 2007
Klaipeda
137
I have ~20 devices with fiber optic interfaces and modbus rtu protocol. I need to connect them to PLC with modbus TCP protocol.
Maybe anyone had similar project and can suggest other solution than installing separate converter for every device.
I was looking for serial to ip server with several serial interfaces, but with no luck yet.
the way to go would be to use rs485 and bring them back to one serial server, like a lantronix or digi. as far as connecting them to the plc, that will depend on the plc and if it supports modbus tcp.
more info you give better answer you get.
1. I have Modbus RTU devices with fiber optic interface.
2. I have PLC with ethernet port and modbus TCP protocol.
3. The task is to establish communication between plc(modbus TCP) and modbus rtu devices.
Hope this makes more sense.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
60
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
266
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
287
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
122
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
552
