Modbus RTU "start topology"
rQx
Oct 2010
Trelleborg
1,051
Would this topology work as Modbus RTU? I wan't to wire all slaves to my cabinet, connect them to terminals and then place jumpers to connect them. Instead of have them from slave to slave.
Yes, this should work. Please review the specifications for RS485 communication on your equipment to ensure you are within them.
Distance - distances up to 1,200 m (4,000 ft)
The value of each termination resistor (If not built into the equipment) should be equal to the cable characteristic impedance (typically, 120 ohms for twisted pairs)
Regards,
Regards,
And 120ohm resistors only to bus ends (master and slave3 on this)
Thanks! Folowup question, isinde a cabinet between VFDs. Is it recommended to use shielded cable also here? Since it's a VFD it will produce noise that will interfere with the modbus communication?
And if it's equipment with no noise, can I use just normal wiring that I twist?
Or what is the standard way?
Use cable with a shield everywhere. Use cable designed for RS-485.
https://www.belden.com/products/industrial/cable/bus-cable/rs485
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
54
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
249
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
284
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
119
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
531
