Modbus RTU
vintoms
Jun 2002
Can Modbus RTU communicate over RS232 COMM port @ 64 kbps? I'm trying to communicate two control logix MCM modules (MVI)
cheers
The MCM is capable of RS232 baud rates up to 115,200. Standard selectable baud rates are 110, 300, 600, 1200, 2400, 4800, 9600, 19,200, 38,400, 57,600, and 115,200. 64 Kbaud would not be a valid selection for the MCM Module and, in 35 years in this business, I can't say I have seen a device communicating at that baud rate.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
114
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
485
