modbus-serial cable for PVplus1000
italo2008
Feb 2009
Padova
95
Hi guys
I need to establish modbus serial communication between a PanelView plus and a Parker motion controller
I use Kepserver and I can simulate the communication with OPC quick client and also communicate with the controller running the FTview project in my PC
The cable PC-CONTROLLER has the following pinout and it works
PC ..........PARKER CONTROLLER
2-----------------3
3-----------------2
5-----------------5
4____
6____|
7___
8___|
There's a jumper between (DTR,DSR) and (RTS,CTS) in the controller serial port. In this situation everything is OK.
Now, the problem is running the project in the panel. Parker told me that this device can use (DTR,DSR) but not (RTS,CTS), so pins 7 and 8 must be jumpered.
I've tried a lot of combinations but I can't crack it. Can anyone help me with this problem?
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
152
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
325
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
131
Hello plctalk, I am in the proces of integrating a Micro820 with the purpose of getting data out of 4 AB Powerflex 4M drives through Modbus...
1,804
Hello guys, I am new to WAGO PLCs and e!****pit. I am trying declare variables from a Modbus Slave Connected using serial to WAGO PFC200 and pass...
1,347
