Modbus TCP and Omron CJ PLC Communication
drunken
Jul 2005
SomeWhere
Hello;
I have an acs800 ABB drive RETA ethernet module and cj1m cpu13-etn;
I have configured driver and plc when I ping from PC, both of them responses, also i can ping drive with plc programming software.
I tried a modbus tcp software to check if driver comm. configuration is ok.
I want to learn that if there is a way to implement modbus tcp plc programming for cj series plc .
it seems to be made with socket service commands but I am confused.
Has anyone ever tried it ?
Can you give me some tips for first steps.
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
307
Hello Is possible to communicate an PLC Omron CJ2M CPU33 with HMI thorough Modbus TCP, if is possible, how? whats is de modbus map register Thanks
4,630
Is it possible to use the same ethernet card (ETN21) for HMI connection and also for Modbus TCP/IP server, connection are via a standard switch...
9,813
(Note: also posted at MrPLC) The results from a Function 03 (Read) splits the high/low byte of the returnd 16 bit words. Neither of the 4 bit...
3,247
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
208
