MODBUS TCPIP more than 40064 error
Aimin Ariff
Mar 2023
Selangor
28
Hello brothers
Now I have problem in taking data, I use modscan32 to try to see values from modbus tcpip, for input registers, address 40002 until 40070, the problem is I cannot see data up to that address, it shows "modbus exception response from slave device".. But when I set to 64, it doesnt show that error and display data up until 40064, and I try again to change length to 66, which is 40066, and there u go, error again..
Same goes in my citect, before this okay when data up to 40060, now 40080 all turn #BAD.. please help me.. Thanks in advance
#freepalestine #humanity
Hello,
Try it with our free slave simulator and if it works, it would appear the device you are using does not support the addresses.
Hi All, We are using M580 Level 4 Hot Standby System. We are using the BMENOC0301 module to do Modbus scanning from the Modbus units (Genset...
2,332
Good day Could somebody please help. I'm sending a position and a speed to a motion task in a Kollmorgen AKD servo drive from a Delta PLC via...
1,340
Hi there. I am developing a logic using commreq for communication between two ge plc 90 30 using modbus tcpip. i am not able to get data as req...
3,275
Dear sirs, Currently i am working on a project which requires to connect the plc ethernet port to monitoring devices, for your information the...
8,047
I'm looking for a cheap way to read modbus TCPIP data into a PLC and fire some outputs (8-10). We bult a unit using a old SLC 500 and a prosoft...
2,242
