Modbus to Profibus
dexdyne
Mar 2007
CIrencester
53
I know it sounds like I can't make up my mind, but this really is a different enquiry :)
We have a custoimer with a SCADA system presenting a Profibus-DP interface to the outside world.
As before, we have a Modbus-RTU master on our kit.
So I need a device to be a Profibus-DP master, and rmap the info into a Modbus-RTU slave for me.
I have one suggestion
http://www.fieldserver.com/products/gateways/FS-B3512.asp
but I'd love some more.
TVM
David
Take a look at some of the products from Hilscher. This is a unit that I will be trying to be a ProfibusDP master on one side and a ModbusTCP slave on the other. I talked with the Hilscher tech guy in Chicago on Friday and this products sounds like the fit for my needs. They may also have some stuff that goes to RTU also.
http://www.hilscher.com/products_details_hardware.html?p_id=P_4063200c68d68&bs=8
Thanks,
Joe_WaZoo
Hi Everyone! I am feeling some troubles while dealing with Profibus and Modbus. Is there anyone who can help me out in following questions? 1...
2,513
hello I use S7-317 CPU in new project to control production line. I use two old DC motor drives...in old configuration they were controlled...
1,764
Iam working on link PLC S7-317 2PN/DP as master using profibus to two old slave speed drives which have only modbus (rs-485) after search I...
2,027
Hi, On a project, i have to assess the possibilities of communication directly from a Labview application on a computer. Profibus: you need a...
3,292
Hi all I want your advice for my problem : I have two PLC control systems , first is an old one and I use an Intouch Scada system to monitor and...
3,403
