Modicon 984 Plc
Jun 2002
Lahore, Pakistan
Modicon 984 Plc
I am facing a disturbing problem here in 132 MW power plant. Maximum ambient temperature is +45C and humidity is about 55% to 70% and PLC pannels are in Engine room, some times engines trip with out any reason/alarm and restarted again, I feel the behaviour of the PLC power supply is not correct. If any of you have such experience please tell me the remedy.
Also there are about 117 instruments (sensors) such as thermocoples, PT-100s, pressure transducers are installed on each engine and there are total 9 engines. If any one have some calculations of persentage instruments malfuntions allowed with PLC please urgently send it to me. I shall be thankful.
Regards to all
Shahid Iftikhar
The PLC should NOT fail. None of 984 I/O boards should fail either. I have actually been to the product assurance labs at Modicon and have had three products tested there. Two for the 984 and one for the Quantum. They tested to 60 degrees C and much higher humidity. If I remember right, the humidity was tested to 90% humidity. However, it is still possible that the PLC you has a chip that is failing. Nothing last forever and bad things happen.
Hi, I am trying to get a machine started that was moved from one location to another. It has a Modicon 984-A131 PLC. I have Schneider Electric...
1,023
Dear Friends, I have Schneider PLC which is the world's first one Modicon i need software of Modicon PLC 984,it is known as...
968
I have a Modicon 984 and PLC Workshop for Modicon 32 Bit programming software from FasTrak Software Inc. Is there a way to load the program from...
2,819
Hi all, I have been tasked with a project involving a Modicon E984-275 PLC. I have, unfortunately never used this type of PLC before and would...
3,749
PLC Serial Connectivity Issue with a Modicon 984 and Modsoft 2.21 Hello all from PLCtalk.net, wondering if someone has any words of wisdom to...
5,665
