Modicon BM85
Sep 2009
West Indies
Can anyone please help with configuering a Modicon BM85 .Persently we have a BM85 reading from a modicon PLC on the modbus plus port,and is connected to a honeywell PLCG gateway via port 1.Is there any special software required?If so how can I get it and what is the procedure .
Thanks Khameed.
Hi mike, thank you for replaying, i already know how to connect to the BM85 via Hyperterminal or ProWorX 32. My problem here is how to root map correctly to have a valid communication between the DCS and the Modicon via the BM85.
From your PLC, route the MSG instruction as follow:
BM85 Modbus Plus adress/ bm85 serial port#/ Slave adress
The serial parameters between the bm85 serial port and the slave
must be the same.
Hi mike,
let me explain the problem here, a few days ago we had a working connection between the DCS and un modicon PLC via BM85. then we had a power failure and when it was working again we lost the data from PLC to the DCS. The PLC is working just fine but the data does not seems to be rooted properly to the DCS via the BM85. I suspected that the BM85 lost his configuration when the power went out and when i connected to it, there was no modbus address map configuration present. So i figured that was the problem. But i have have a problem figuring out how to configure correctly the table entry for port 1 (See attached).
The BM85 switch is set to the address 5, and connected to port 1. For a table entry, what should i enter as a modbus address and destination address?
Thank you
Hi All, I have a bm85 I am trying to connect to a quantum 984-265 via a bm85-000 base model. I have ports 1-4 configured as P>PORT...
1,648
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
189
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
101
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
108
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
326
