Modicon delete vertical SHRT.
kf5pv
Aug 2008
Fort Worth
39
I am pretty bad in Modicon. I am trying to edit some code, but have made some vertical shorts that I need to remove. I have been reading some and getting close to the end of my 16 hour day, but no luck. I am good to go in AB, but this modicon is for the birds. proworx32. you can see the SHRT's in the attached picture.
TIA
Paul
I "think" you need to put cursor to the right or left of the vertical short and press the minus key. It took me a while to figure this out a year or two ago so my memory might not be correct.
Good luck with the online edits with ProWorks, sometimes it goes ok. Other times not so much
Good luck
ProWorx32 is also somewhat obsolete. Your client should seriously consider upgrading to Control Expert (Unity Pro) if they can.
From memory you need to have the cursor on the horizontal rung left or right of the short and "maybe" press delete or right click and select... it has been many years since i last used proworx. I'd try with a different, offline copy first.
I have tried that. haha. maybe I will try Ctrl. -
Actually I was able to remove one of them, but not the others.
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
189
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
100
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
108
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
324
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
110
