Modicon M258 Logic Controller IPconfig?
peelseeds
Mar 2012
Not at your house.
71
Has anyone ever setup this PLC before?
I am having a tough time configuring the IP.
I've tried DHCP and Schneider BOOTP program with no luck.
I can ping the PLC (default according to manual)
I tried a USB, and the m258 driver gets installed but in SoMachine software there is NO option for USB transfer, I only see Serial.
SoMachine should connect through the gateway service to the Ethernet port. We use the LMC058 and it should be very similar in config. If you can ping it, can you get to the webpage (should be able to)? Then you have to select the correct PLC model in SoMachine and in the Gateway selector it will usually just find it on the web by searching. If you selected the wrong PLC, I have seen where the search will not find it.
I need to design the system using Schneider PLC but pretty new to it. The system that I need to design is pretty small system and I am thinking...
3,733
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,368
i have plc modicon m258 its CANopen bus not running and give status on SoMachine v3.1 red triangle after i make download to it so please how...
1,815
I got brand new modicon M258, with extra DI, DO, AI, AO cards, part number TM258LD42DT4 willing to trade with ControlLogix 5000.
1,334
We are running into some issues with serial communications dropping out after a few days. When viewing the PLC hosted web page, we found the...
2,381
