Modicon PLC Upload problem
ry_fern
Jan 2008
Caloocan City
44
Hi guys!
I would like to seek for your your help.
We have this project to integrate another Weak Acid cation vessel with the existing program. The problem is we don't have a backup of the latest running program in the PLC. When I try to upload it, only the configuration is uploaded. The program sections are not included. I understand that the IEC Upload information was not included by the programmer which makes the program disabled from upload.
I badly need the running program in the Momentum PLC, is there another way to upload the program?:cry::cry:
Any suggestions will be much appreciated. Thanks in advance.
Nope - if it's programmed in IEC, and the upload wasn't enabled when it was sent to the PLC, you won't be able to extract it from the PLC. You'll need to get the original files from the programmer.
Kenschunk,
Thank you for the information. This is what a simple failure in backing up files can cause someone a lot of problems. Unfortunately, the programmer has lost his backup. I only have his early programs that has been modified so many times.
I know this may sound funny but how about entering (or hacking) the very CPU of the Momentum?
Thank you.
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
383
I have a TSX P57102 PLC and XBTF024510 screen. The screen is connected from the 25 pin port to the term port on the plc. I tried to connect to...
6,587
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
314
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
415
We've got this old Modicon PLC on a Mobile Skid that has developed "Comm" errors that cannot be cleared (tried moving cables, connectors etc.)...
1,095
