I'm translating some old modicon code. First time I've worked with modicon in any deep capacity.
Just want to clarify the output operation of a counter...
In the example from this screenshot what can I expect in regards to the output state when the counter is done.
1 - Once the count is done will output 01445 be active for only 1 scan due to the rising edge of 10006 or...
2 - Once the count is done will output 01445 be active as long as 01038 is high.
I guess what i'm wondering is if the count is done will the output stay high if the reset input stays high even if the count / control condition ceases to be on. Or is that required for the signal to pass to the output.
Thanks,
Thanks,
