Modicon Quantum Flash Memory
EStranz
Nov 2003
Does anyone know how to load a program into the flash memory of a Modicon Quantum 434 Processor? I'm using the ProWorx Nxt programming software. After going onlline I tried to do it via ethernet with the processor stopped of course, and it locks up and gives a communications time out. I then thought that maybe when it tries to flash the memory that it looses control of the Ethernet card so I used my Modbus cable and got online with that and tried it and got the same result. Am I doing something wrong? Every time the processor looses power it reverts back to an older version of the program because that is what is loaded into the eeprom.
This should work, I did it some time ago with 434 12A processor.
First: to prevent writing from flash to RAM set MEM Protect switch to ON.
Warning: Memory Protect is a switch on your controller that stops you from altering the controller's contents. The Memory Protect switch should be ON or the card overwrites memory on power up.
I can't verify write procedure now, but I think you have to clear flash before writing. Button should be on the same dialog.
Also Flash may be smaller than total amount of data you writing.
Just a guess here.
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
275
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
657
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
501
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,867
System Details: We use hot redundant Modicon Quantum PLC with dual redundant communication having Remote IO racks (using CRP + CRA cards and...
777
