Moeller PS416-CPU-300
Lost_Raiders
Feb 2017
Warrington
Good afternoon ladies and gents.
One of my potential customers currently has a Moeller PS416-CPU-300 PLC and we're looking at upgrading to a S7-1500.
THE BIG QUESTION IS:
How on earth do I pull a backup from the existing PLC.
Can you give specifics in, and correct me if Im wrong: Software needed (Sucosoft S40?), Machine to use (xp im guessing), what type of cable I would require etc.
It'd be a mahoosive help if you could provide any documentation with the process of the Moeller programming so come development time I wouldn't be going in blind.
Cheers
C
If the PS416 is like the smaller controllers that use Sucosoft then you will probably not be able to pull a backup from the controller. The only possibility is if the last person that downloaded to the controller put a copy of the source file on it.
If they did not, you can get a compiled version that you could use to put on a new controller in case the first one dies but no way to look at source.
I never dealt with the 416 so I won't be any help with cables but hopefully you get lucky and the original programmer was thinking about you when they did their work.
There is a manual here:
http://www.klocknermoeller.com/automation/ps416/pdf/h1208g.pdf
Is it possible to extract and read the code from a PS416 CPU-200 plc without the original source code using Sucusoft S40 V5.02.(or other method) I...
2,935
I have a problem, I can not read the contents of Moeller PS416 PLC CPU400. Connects to the PLC and gives mii option to record the program...
2,047
Hi.. We have 3 units of Klockner Moeller PS416 PLC with CPU 223 as stand alone and we want to collect the data to our RSView32 station. We plant...
5,057
Hi group, We have a bit of an issue which I am sure you guys have heard before, I did look at the previous threads but could not see if there...
540
I am looking for leads on getting a manual in English for the Klockner Moeller VTP HMI software. The software is VTP and was DOS based. From what...
560
