Moeller
lab
Nov 2003
48
I'am wondering if anybody has had experience with the x-series of the moeller plc? good , bad, or otherwise. The rep was down today and put on a bit of a demo with their xsoft software, really neat looking stuff.
Thanxs in advance
Best Regards
Lab
We've sold 1 system with an XC201...XV and are now working on two more with the XC100 and XV-101-K84 character based HMI.
Our initial application is also using a VB.net app to extract data from the processor via the provided OPC server.
I think the visualization and simulation are fantastic. You really can simulate your whole machine before pulling a wire. Also, the Web server is pretty cool. As soon as my in house XC201 is not being used for some testing, I'll put it online for all to see.
If using with a Moeller MV4 HMI, DO NOT use the CANopen interface. Currently the Serial is the way to go; ethernet will be available around March they tell me.
We used the XI/ON remote I/O and that worked fine after learning a couple setup details but for some systems it would be cheaper to use another CPU as a remote I/O rack if needed. The CPU's themselves come with 8 Inputs and 6 Outputs (24VDC PNP interface). CANOpen is built into all the CPU's. Only the XC201 cpu's have the ethernet interface. Only the XC201's with the XV at the end have the Web server.
The controller does have file handling capabilities since it is based on Windows CE but these take longer to execute than the rest of the program so you have to account for this if you want to use them. But on the other hand, not many PLC's can write to a file directly that you can then offload from a built in ftp server. Note that the version of Windows CE it uses is closed. Thus, you can't run any of your own applications on it.
If you have any more questions please post.
**Disclaimer** I work for a Moeller Distributor.
Hi group, We have a bit of an issue which I am sure you guys have heard before, I did look at the previous threads but could not see if there...
543
I am looking for leads on getting a manual in English for the Klockner Moeller VTP HMI software. The software is VTP and was DOS based. From what...
565
Hi, First i'm a beginner and not a very good in english so i will try my best to be clear ! I work on an used installation and me and my team has...
675
Hello! I have a friend who now lives on his boat in a different country and he has reached out to me for some help. I am familiar with the PS4...
1,666
Hello, I recently got my hands on a moeller ps4-341-mm1, I do not understand this plc it won't boot. In the manual on page 65 says "The Run” and...
1,303
