Monitor Output Word in S7
No. What I do is use a temporary location to "see" it. For a testing example put a rung of logic in that Moves MW100 into PQW300. Then you can monitor/modify MW100 and you will see the raw counts being sent to the PQW.
As a general programming practice I always create a data block location for the PQW value. For example in logic I will unscale to the DBx.dbwxx location, then move DBx.dbwxx to the PQW. This allows the raw counts to be monitored by the programmer as well as displayed on the HMI.
Or you could just monitor it in the Hardware Config.
300 and 400 IO-cards (both digital and analog) can be monitored in the HW-config. This is especially nice for AO-cards. Only drawback I've found is, AO-card cannot be monitored if they aren't on the main rack. (in our configs)
So, depending on your configuration, it's possible.
I'm playing around with the pulse output functions of Omron CP1L and I would like to monitor the output frequency in data trace. I do not see a...
6,518
hello friends is there any way to monitor PQW using simatic or even protool runtime and plcsim?
1,735
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
107
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
198
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
374
