monitor rslogix 5000 a tag
mike3475
Feb 2013
brooklyn ,NY
334
Hi,Guys:
we want to monitor a tag (PF525 drive output current) when drive output current is over the threat point at what exact time, we can use trend, the problem is we don't know when it happens, it could be once a week or twice a week, it very hard to trace it. we may use HMI to set up a alarm, but we didn't find a trigger point yet.
anybody has a idea?
thanks!
Assuming you're using Logix5000 you could set up a Message instruction to do a parameter read and read parameter 3 from the drive. Divide the value you get back from the drive by 100 and that will give the actual current of the drive in amps. Compare this to your limit and use the comparison to trigger an alarm if it ever goes above your limit then you'll have a log of when it happens. You could also compare the actual current value to another tag for the peak value so you'll know what the highest value the current has been.
we want to know when the drive output current is over our set point.
for example: the drive output current is over 6A (set point) at 6:39 PM 1/9/2019, in fact we want to know another tag activity after this moment.If we don't use HMI.
Thanks!
We implemented a poor man’s version of value trapping using the built-in digital alarms logged to an SQL server. The almd instructions allow for extra tags, we point them to the relevant tags in the PLC. After the fact, we look at the alarms in SQL and can tell exactly what tripped them, and when.
We put an almd instruction on a rung and set up the conditions ahead of it. Create the alarm tag, then use 0,0,0,1 as the parameters. Open the alarm definition, put in a descriptive message. Then, add any related tags. In your case I would put the drive current, the setpoint if it changes, and the other tag you were concerned with. When the rung goes true, the alarm will trigger. If you are going to an SQL server, a timestamp will automatically be captured.
Dear All, Is there any way to simulate vibration program on RSLogix 5000 using Emonitor? Regards, Mitsupuri A.P
2,507
To All, Please help, I am new to Rockwell automation and normally use Siemens, I am trying to finish up a program and now need to use a "Heart...
18,113
I know this is an old issue but it never hurts to ask. Is there a way to do data monitoring on RSLogix 5000 without using the Custom Data Monitor...
7,614
Hello, guys, I have Control Logix already running and i want to see 20-30 tags together. It eazy to do with RSL5 or RSL500, it helps me a lot to...
5,798
RSLogix 5 has a nice feature - custom data monitor. RSLogix 5000 has a Watch Window. I haven't found a way to populate the watch window with...
17,161
