Most wanted, S7-400
Nov 2014
ulaanbaatar
Im newbie for Siemens PLC. Know and programming on S7-400 little bit.
So i'm going to make my first project.
then i dont know what plc is fit for my project.
Pls help me choose
1. CPU
2. Communication module
3. Analog in/out module
4. Digital in/out module
3 analog input, 3 analog out, 6 digital input and 6 digital output use for my project.
My project about automatically control valve depending on tank level.
and monitoring and controling from Wincc
pls write module's part no.
and give me some advice
Please help mee
Hi tsenguun,
Siemens S7-400 is a very powerfull PLC usually used for quite big installations. If you don't plan to make your application much more bigger an S7-400 would be an overkill. For proposed application an S7-1200 would be powerfull enough and the programming basics are the same (if using TIA Portal), with same diferences.
If you want to use STEP 7 5.5 then i would use an S7-300 with a 312C and with modules (6ES7331-1KF02-0AB0 + 6ES7332-5HD01-0AB0).
Best regards,
Kelkoon
312C is obsolete. I would not recommend it, or anything else without ethernet onboard.
S7-1200 would be an OK fit. S7-1200 is programmed with STEP7 TIA.
IM151-8 with ET200S modules would also be an OK fit. IM151-8 is programmed with STEP7 5.5 (aka "classic").
If you want to go this way, I could specify the part no's for you.
Hello Mr. tsenguun odgerel,
If you work only for a small project, and you like siemens PLC's, S7-1200 is suitable for the job, and not that expensive. Simatic Step 7 V11 (TIA portal) is similar to simatic manager step 5.5, the OB's, FC's, Data block and so on. Just compare the price for the logo and the s7-1200. I had tried once the cpu1212c and it only cost me a 950 Riyal= around 180 USD.
I'm using raspberry pi 4b to poll 3 different plcs with modbus tcp and then publish the tag data using mqtt sparkplug b back to my Ignition...
3,459
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,861
Greetings to all ... I've never owned or needed a household generator – but current conditions have convinced me that now's the time to buy one...
23
6,911
With the Automation Directs Open Source Arduino Compatible PLC and the Open plc Project, plus all the Raspberry Pi HMI's, what are your opinions...
4,332
Attention all PLCs.net members!! As Covid-19 has put many of us factory automation folks out of work, let’s work together to help get as many of...
18
19,568
