Motion Control thru Counter modules
Tweeker
Nov 2007
Smalltown
79
Can anyone give me the basics of how motion control to a servo or stepper drive is accomplished through a counter module in the PLC rack?
Thanks.
Which PLC?
Some examples from Omron [CJ1M, CP1H and CP1L] and from Idec [ MicroSmart] Series.
These have high speed pulse outputs that are capable of generating relatively simple motion profiles suitable for connecting to Stepper or Servo drives that accept [typically] pulse and direction inputs.
Don't expect tremendously sophisticated motion control using these units, however they do offer a low cost option for straightforward applications that do not involve multi-axis coordinated control.
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
74
I have always controlled servos in Rockwell motion using position loop. I have an application where one process will push against a servo...
297
How do I adjust motion control parameters using Logix Designer? Such as: motion axis stop I will make an adjustment like changing the...
330
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
958
HI using a G120 sinamics i used the Profidrive in order to control the position in the picture i showed how my system is ,alos how i set the...
1,087
