Motor on PF755 vibrates at standstill
taylor1982
Aug 2011
Bavaria
78
Hi all,
I have a 100hp torque motor running on a Powerflex 755 drive. The motor is coupled to a drum which is accellerated and decellerated.
The problem now is, that the drum start to vibrate when the drive is enabled and get set speed = 0. This happens not every time and when you turn the drum manually just a bit then the vibrate is gone.
Has anybody hints what could avoid this vibrations? I did the Autotune with the drive an all other functions are fine.
Thank you
Steve
Do you still have run 'run' high when command is 0 ?
Yes, actually the run is always high and i just manipulate the reference speed. Of course a FALSE on run would help but are there any solutions that would avoid the vibrations even when drive is in control mode?
Is the control 4 to 20 mA or 0 to 10V etc ?
There maybe tiny variation in plc signal or noise like emc causing the drive to pick up a speed reference. Does the vibration go away if you disconnect the speed reference
Been a while since I worked with this drive. If I recall correctly you could use the Sleep/Wake parameters [351-355] to limit movement until a minimum reference level [Volts or Current] is reached.
I completely control the drive with Ethernet/IP. I think it has something to do with the drive‘s internal management when in control mode and Target speed 0.
Maybe it toggles between encoder increments and that causes this vibration around standstill speed. The motor has an 2048 increment encoder.
Thanks for that hint! I will have a detailed view on that parameters the next days and will give feedback.
Hello, fellow PLC enthusiasts, I’m a newbie in PLC and am currently on a project that involves connecting an Omron CP1E (CP1W-CIF11) PLC to an...
34
I had trouble for a week trying to get a Marathon Symax Motor autotuned to work with a Powerflex 753 drive. I solved the problem and thought I...
63
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
320
254
359
