MOV Instruction
oxlacey
Aug 2012
SC
38
This should be easy (I hope).
I have a MOV statement with no conditional. I want to move 6 into Number (integer).
However, it never happens. Number remains 0.
What am I missing?!
In addition to checking to make sure the subroutine is being called make sure that something else is not clearing the integer register.
oh my gosh i feel like the village idiot. sorry for that guys, it's been a while since i've actually had to program! i forgot to call the task.
OK. now that works.
I want to put a variable into a tag called Rack_Contents that is a DINT with 13 elements (for 13 racks).
How do I move a value of "6" into Rack_Contents for rack number 11?
I can do this with 2 MOV statements; is there a way to do this with a single MOV?
It kind of depends on how you refer to the 'Rack Number'
Is Rack_Contents[0] called "Rack 0"? If so then rack number 11 is Rack_Contents[11] and placing a "6" in it would be:
MOV 6 Rack_Contents[11]
But realize this method means you cant have a Rack Number 13. The last one would be rack number "12"
I make arrays one element larger when needed so for 35 racks numbered 1 to 35 I create my array as 36 elements. You get Rack[0] to Rack[35], and you don't use rack[0]. It wastes an element, yes, but it is simpler to program.
Is K4M101 a constant? Is K7 a constant? What does this instruction do? Thanks
19
5,174
I have to create a sample mov template in add on instruction.I just want to know the list of tags which is used to create a mov logic instruction...
2,102
Good evening! I am having trouble making this work. I need the counter to count up to 3 seconds if the DI_01 is off, and to count up to 30s if...
2,127
Hi everyone, I have a short question about BLKMOV instruction, illustrated in the image below. I have the same piece of code in STEP 7 (ET200S)...
2,725
Hey I was having some problems with a MOV instruction. I have a pressure that once it reaches a certain pressure I want it to close two valves...
2,439
